Change battery and network icon behaviour
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-26-2023 01:20 AM
It is possible to change your battery icon in the status bar to show you only the battery percentage, but it does not show you the lightning icons that tell you the phone is charging. Please add the lightning icons back.
Also, the network signal is for some reason coupled with the 4g icon. I'd like for that to be separate in order for me to be able to disable only the network icon.
Thanks!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-28-2023 05:48 AM
Hey @redstonerti,
Thank you for the feedback, I have forwarded your suggestion to the R&D department.
