06-04-202006:21 AM - last edited on 01-16-202412:57 AM by ZenBot
I had found a bug in fingerprint on the asus zenfone max M1. The fingerprint lock screen adding option is missing and also the fingerprint sensor is doesn't working. This problem is arrived on a few days after the latest security patch system updation. I had tried solve the problem by doing factory data reset. And doesn't worked. You are want to fix this problem new software update. By your customer Thank you.
