Hi iammigs1126,
Do you feel like battery drain after using the phone or in stand by without using it?
If while using the phone, does battery drain while using any specific apps?
Please tell me the app and the battery variation while using it for a certain time (e.g. 1 hr).
If you feel like the battery drains during using specific apps, we would suggest you test how much the app drains after using it for a certain time.
We would suggest you clear the background apps, and check how much battery is consumed from 100% after using the app for a certain time (e.g. 30 mins or 1 hour.)
Please show me a screenshot of the battery usage after testing.
Settings > Battery > Three dots on top right > Battery usage.
