ZenFone max pro m1 after update wifi hotspot stopped working
caballerrro
ZF Model: ZE554KL
RAM: 3G
Firmware/APP Version: 9
Frequency of Occurrence: 1
Rooted: No
APP Name:
Last edited by caballerrro on 2019/7/16 17:48 Well, after 10 days of total dissapointment using this ZenFone max pro m1 i return it back to the seller. And i will never recommend an Asus to anyone.
ServiceH_ASUS
Hi caballerrro What's your phone’s firmware version (Settings > About > Software information > Build number) If there any error message pop on screen? Have you tried it under "safe mode"? In safe mode, only the factory pre-installed applications will be loaded. For instructions, please refer to the link below: https://www.asus.com/support/faq/1005163 Thank you:)
shawn_e_frey
multiple issues with this update and still no fix?
