Auto Brightness
PCG
It's too dim. It sucks because every time i have to adjust it.
4 REPLIES 4
rynn_chew
Hi joegan79, May I know which firmware version is your phone currently having? Since when does it start happening? Is brightness level in setting set as automatic brightness?
PCG
Since Pie upgrade. Ya. Auto Brightness too dim
rynn_chew
joegan79 posted on 2019/7/16 20:05 Since Pie upgrade. Ya. Auto Brightness too dim
Hi joegan79, Please try back up your data and perform factory reset to see if it works.
MR_NOBODY96
I face same issue here, but after you update patch june 2019, the problem will solved..great job Asus..keep hear our problem and do something!
