[ZB602KL] Can I download firmware or how to update firmware for android 9 & 10
Kator
No firmware to download is manually : https://www.asus.com/supportonly/zenfone%20max%20pro(m1)(zb602kl)/helpdesk_download/
WW//WW_PHONE-15.2016.1902.340
Falcon_ASUS
@Kator
If you have a need for a system upgrade across versions, we recommend visiting a service center where our staff can assist you.
You can find service center locations at the following link:
Is this the most correct and appropriate thing to recommend?
