05-27-2020
12:09 AM
- last edited on
01-16-2024
01:10 AM
by
ZenBot
05-27-2020 08:03 AM
RatanI also used to have 3 sim... The sim that i personally use didn't show the volte for long time after several complains it never got fixed so i port that sim to airtel. Then comes the second sim which was used on redmi note 4 but never showed volte on max pro m2 but volte was working on redmi note 4 so i changed the sim and the volte works perfectly fine.. then comes the thrid sim which shows volte from the beginning and never had any issuesI used 3 Vodafone sim but the problem are same
05-27-2020 08:05 AM
05-27-2020 11:01 AM
05-27-2020 11:05 AM
Riju9547Then how the hell my sim works with a fu*k load of other phones? Nokia 6.1, 6.1 plus, several samsung models, a oneplus model! So, you're basically saying those manufacturers have an affair with vodafone. 😂This is the problem with Vodafone use other vodafone number you will see the volte is working asus has nothing to do with it.. i have the same issue so i change the sim and my problem was fixed. Vodafone will never acknowledge this as a problem.
05-27-2020 06:02 PM
arpand06Then whats about this vodafone sim in Redmi note 4... In RN 4 the volte is not working with one vodafone sim but working on another so now its Xiaomi's fault. And my volte is working fine in max pro m2 only for some vodafone sim ... I dont know what vodafone is doing but there volte doesn't work in some sim also in some devices the volte works but in others it doesn't and vice versa.https://zentalk.asus.com/en/discussion/comment/83706#Comment_83706
