ASUS ZENFONE MAX PRO M2 ANDROID 10 ( STABLE / DEVELOPER VERSION) Bugs
BANIK_AJAY
Model Name:ZB631KL/ZB630KL
Firmware Version:17.2018.2004.424
Rooted or not:Not
Frequency of Occurrence:New
Build info: sdm660_64-user 10 QKQ1 41 release-keys
Serial number: JCAAGF04D340YZW
i was found Android 10  STABLE / DEVELOPER VERSION Same Bugs .
1. Customies your ZB630KL It is showing. Even I try all customized.
2. The search button was not fixed when I scroll down and scroll up then search button was moved.
3.The sound was not fixed. When I try to full sound. The sound was not good but when I try to sound medium then I can't even hear. And also my headphones sound was not good it seems like the sound was bold it not soft and it too irritating. that bcz i can't even play game bcz of sound . that foot step was not clear.
4. Again Corner problem. corner was not round. fix this bugs as soon as possible.
victor010
Zen Master III
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
BANIK_AJAY
When We get android 10 stable update ?
