Video camera for max pro m2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-15-2020
06:00 AM
- last edited on
01-16-2024
01:17 AM
by
ZenBot
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
While shooting video it keeps focusing and sometimes very blur.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-15-2020 04:14 PM
venkatetYeah, my bad. I just checked that I have disabled the stock camera app year ago. The settings I have mentioned you earlier with the autofocus options, they are available in Asus PixelMaster camera app which I use for video recordings and I use Gcam for capturing images.https://zentalk.asus.com/en/discussion/comment/71849#Comment_71849
There is no options for setting continuous and smart auto focus
Since Stock camera app has lot of limitations, you should try enabling the Camera2API, but before going to proceed for the steps, I would like to ask you to wait for the Stable Android 10 release, in which the Camera2API module may get enabled by default for all. If not, then I would definitely let you know the steps which are simple ones, and enabling Camera2API doesn't void warranty either. Just keep using the stock camera until the stable Android 10 gets released within a month from now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-16-2020 04:22 AM
SanjuThank youhttps://zentalk.asus.com/en/discussion/comment/71866#Comment_71866
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-16-2020 06:23 AM
SanjuI have unlocked the bootloader, and relocked it now. I am unable to get ota ..eventhough some time I get it is not working. Any solution.https://zentalk.asus.com/en/discussion/comment/71866#Comment_71866
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-12-2020 02:54 AM
1. Check your phone for latest software version. Click here: https://www.asus.com/in/Phone/Zenfone-Max-Pro-M2-ZB630KL/HelpDesk_BIOS/
2. Go to Camera settings & try changing focus mode
3. Clear cache & storage of Camera App after backing up & disable/re-enable camera App
4. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
5. If still you face the issue factory reset your phone after taking a full backup.
- « Previous
- Next »
