not able to update
Model Name: Zenfone Max Pro M1
Firmware Version:PKQ1.WW_Phone-16.2017.2002.061 20200219
Rooted or not:No
Frequency of Occurrence:High
not able to get the notification for update file detected on my phone. I've downloaded the android 10 firmware zip for my phone and placed it in the root directory of the phone , restarted several times no notification. The zip file is not corrupt and tried clearing data of the FOTA services app, nothing happens.
4 REPLIES 4
Shahed
Firstly , why do you want to update?
If you are planning for migrating to Beta, then i would suggest , just don't update to beta , because as it's the mid april and the stable update might arrive in the end of this month or in the first week of may.
So just be patient and stick to the firmware you using now.
Shahed
as you suggest
BlueHunt
Zen Master I
charanjeetkaur2211
https://zentalk.asus.com/en/discussion/comment/71810#Comment_71810
as you suggest
In addition with @Shahed 's comment, with which I completely agree, you cannot upgrade to the 10 beta AOSP version if your current Firmware version is .061. Your device could only detect the 10 beta firmware if your device run on.059. otherwise as Shahed said, you absolutely don't need to upgrade to the beta 10 while the stable release is just 1 month away.
victor010
Zen Master III
Hi there, you may click on the following link to download update manually, request you to read the instructions before upgrading and take a full backup of the device before. Click here: https://www.asus.com/in/Phone/ZenFone-Max-Pro-M1-ZB601KL/HelpDesk_BIOS/
Kindly click on the following link for instructions on how to update manually: https://www.asus.com/support/faq/1009748
