04-15-2020 06:00 AM - last edited on 01-16-2024 01:17 AM by ZenBot
04-15-2020 04:14 PM
venkatetYeah, my bad. I just checked that I have disabled the stock camera app year ago. The settings I have mentioned you earlier with the autofocus options, they are available in Asus PixelMaster camera app which I use for video recordings and I use Gcam for capturing images.https://zentalk.asus.com/en/discussion/comment/71849#Comment_71849
There is no options for setting continuous and smart auto focus
04-16-2020 04:22 AM
SanjuThank youhttps://zentalk.asus.com/en/discussion/comment/71866#Comment_71866
Since Stock camera app has lot of limitations, you should try enabling the Camera2API, but before going to proceed for the steps, I would like to ask you to wait for the Stable Android 10 release, in which the Camera2API module may get enabled by default for all. If not, then I would definitely let you know the steps which are simple ones, and enabling Camera2API doesn't void warranty either. Just keep using the stock camera until the stable Android 10 gets released within a month from now.
04-16-2020 06:23 AM
SanjuI have unlocked the bootloader, and relocked it now. I am unable to get ota ..eventhough some time I get it is not working. Any solution.https://zentalk.asus.com/en/discussion/comment/71866#Comment_71866
05-12-2020 02:54 AM
