Suggestions for Android 10
vishalsr098
1. Fix the sound problem- make it loud and clear like at the time of Android oreo.
2. Fix Haptic feedback vibration.
3. Add HD graphics for Pubg.
4. Fix unlocking issue.
5. Fix the setting suggestions issue.
6. Give the Files app by default.
7. Fix brightness issue.
8. Enable camera2api for installing Gcam.
27 REPLIES 27
VEL_ASSA
Rising Star II
Call waiting not working on android 10 beta 2
VEL_ASSA
Rising Star II
Call waiting service not working on android 10 beta 2
Y_ASUS
Zen Master I
Hi vishalsr098,
Please provide your firmware version: Settings > About phone > Build number.
1. Fix the sound problem: Could you describe in more details about the sound problem? Is the volume lower in Android 10? Is the problem in speakers or headphones? What app does it appear in?
2. Fix Haptic feedback vibration: Please go to Settings>Accessibility>Vibration& haptic strength
3. Add HD graphics for Pubg: This issue is under investigation.
We will notify you once we receive any update on this issue.
4. Fix unlocking issue: Could you describe in more details?
5. Fix the setting suggestions issue: Regarding the inability to remove the recommended Settings, after investigation, the Android 10 platform AOSP system does not provide a removal solution. In order to maintain the stability of ZenFone Max Pro M1 in Android 10, we will continue to provide the recommended Settings. If you have already performed the recommended settings, we suggest that users ignore them and we apologize for the confusion.
6. Give the Files app by default: We can find the Files app in all apps list.
7. Fix brightness issue: Could you describe in more details?
8. Enable camera2api for installing Gcam: Do have a error screenshot? What's your Gcam version? What errors are you facing during installing Gcam?
Thank you 🙂
Y_ASUS
Zen Master I
Hi svela003@gmail.com,
Could you check if you've enable call waiting function? (Phone app > tap upper right three dots > Settings > Calling accounts > Tap your SIM card > Additional settings > Call waiting.) Please show us a screenshot of this page.
If the problem still appears, please provide your operator name and show us a short video of the problem.
