Asus zenfone max pro m1
ZT-552fd478
Asus zenfone max pro m1 android 10 424 update many many bugs
1/ speaker problem
2/ heating issue
3/ battery draining problem
Please fix upcoming update 🙏 please release upcoming update quickly
Y_ASUS
Zen Master I
Hi bijoyp18098@gmail.com,
Could you describe in more details? What app/app version are you using? Do you have a music link you can provide as an example?
Which part of the phone does it heat up? Does it appear after any specific actions? Please refer to this FAQ: https://www.asus.com/support/FAQ/1011555/
Is battery draining in use or in sleep mode?
Y_ASUS
Zen Master I
Please check your inbox for a message I have sent you.
Thank you 🙂
