Sound quality is cracked
ZT-dec80e76
Model Name: Max pro m1
Firmware Version: 2017.429
Rooted or not: not
Frequency of Occurrence: everytime
APP Name & APP Version (If your issue relates to the app): sound quality
Hey guyz my max pro m1 sound quality getting wrose like the speaker/wired/Bluetooth sound is cracked and it's too annoying from Android 10 beta 3 (429) update and it is bug from earlier beta updates but this problem was to get solved earlier after clearing storage of "Device Configuration". But after this beat update i had tried 15 times but that trick is not working. So tell me the solution guyz. I had tried many myths but doesn't work any of them
4 REPLIES 4
victor010
Zen Master III
 Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
bharat_lal00
Same problem is here , if this will not solve I break this phone and never will buy Asus phone
abhaykrishnan02
Zen Master I
bharat.lal00
please don't break ur phone
u can give it to me
6pslima2002
This problem can be solved using an ADB command. Search for "max pro m1 sound fix using ADB" on YouTube
