some Pie problems and question about reverting to Oreo
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-05-2019 01:09 PM
ZF Model: ZB602KL
RAM: 4G
Firmware/APP Version: WW-16.2017.1905.053
Frequency of Occurrence: always
Rooted: No
APP Name: n/a
Last edited by zrx8 on 2019/6/5 21:38 Here are some of my findings with Pie, mostly usability related: The "connected devices" settings submenu structure is somewhat botched:
RAM: 4G
Rooted: No
APP Name: n/a
- The "pair new device" appears twice, in the upmost level of the "connected devices" menu as well as in the bluetooth submenu
- The bluetooth switch is buried pointlessly deep in the menu hierarchy
- The temporary bluetooth visibility of the device cannot be explicitely turned on, this is annoying and ambiguous as the user doesn't know when the device is temporaly visible (and has no control over it ?)
- The "available devices" doesn't display the earlier paired ones, this is frustrating until the user discovers them in the "previously connected devices" list
- There is no point, why the big battery symbol is not clickable anymore. The "battery usage" graph can only be opened through the ... menu, which is one more unnecessary click. Totally inconvenient.
- The "more than 2 days remaining" near the big battery symbol is uninformative, and is inconsistent with the remaining time displayed under the graph
- The arrangement of the menu entries in the "battery" menu seems to be ad-hoc, all the time-related entries (remaining time, last full charge, screen usage) should come first, grouped thematically next to each other
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-20-2019 08:27 PM
zrx8 posted on 2019/6/18 18:28 Hello, Any updates concerning this post ?Hi zrx8, the wifi became less stable with Pie --> Please try resetting your network settings and try again. (Settings > System > Advanced > Reset options > Reset Wi-Fi, mobile & Bluetooth) Could you tell me the brand and model of the WiFi router that has this problem? Have you tried connecting to a different router? Do other phones connected to this same WiFi have the same problem at the same time? Please show us a screenshot of your WiFi information. (Settings > Network & Internet > Wi-Fi > tap on the WiFi already connected > Advanced) Thank you 🙂
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-20-2019 08:31 PM
hafidzlatifh posted on 2019/6/19 21:40 And I get problem with connection, after get FOTA Update and updated it, the connection being more s ...Hi hafidzlatifh, the connection being more slower --> Does it happen when connected to WiFi or 4G? Please try resetting your network settings and try again. (Settings > Connections > More > Network settings reset.) WiFi: - Could you tell me the brand and model of the WiFi router thathas this problem? - Have you tried connecting to a different router? - Do other phones connected to this same WiFi have the sameproblem at the same time? - Please show us a screenshot of your WiFi information. (Settings > Network & Internet > Wi-Fi > tap onthe WiFi already connected > Advanced) 4G: - Please tell me your mobile network provider- Please show me a screenshot of the signal strength when the problem appears. (Settings > System > About phone > SIM status) - Please change to another SIM card by another network provider, and check if the problem still appears. Please also put your SIM card into other phones and check if the problem appears. - What kind of location does this happen? Are you in any building/ on a transportation/ in the basement/indoors or outdoors?Please check in other locations as well. Thank you 🙂
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2019 02:40 AM
I have issues with system taking too much RAM. My RAM was filled by 60% before update. Now it's 98%. System itself takes about 3.3GB now. I need to know, when you'll release new system update with system optimization, because the keyboard (Gboard (I don't use any other keyboard but preinstalled)) crashed much times when typing this message.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-24-2019 01:09 AM
Jei_ASUS posted on 2019/6/21 10:31 Hi hafidzlatifh, the connection being more slowerHow about games still dont get High Frame Rate mode? and missing some graphics effect? will u guys do something about this? so i played AoV and we are missing High Frame Rate Mode in latest Pie Update. please we need fix because its frustating for AoV player use Zenfone Max Pro M1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-26-2019 07:58 PM
I have problem self restart on my phone more often after update pie..
Please give for solution..?
