Severe Battery Drain issue!
kirandesai1994
Model Name: Asus Zenfone MAx Pro m1
Firmware Version: WW-16.2017.2004.063
Rooted or not: Not Rooted
Frequency of Occurrence: Daily
Facing severe battery drain issue. There is definitely a bug with software, the idle battery drain is too damn high. To make it worse, the phone struggles to even give a screen-on time of 3 hours now and refuses to charge till 100 even with the supplied charger. One of the most peculiar thing i found out was my phone died due to battery drain, i connected it to the charger and booted it, and suddenly the battery is at 56% ?! Can someone please fix this? It's a very serious issue considering the times that we are living in!
6 REPLIES 6
carlinfernandes
Update to A10 and enjoy good battery
akashvenu15
Same issue .My battery backup has only become worse in a few days . I hope Asus looks into this problem
kirandesai1994
carlinfernandes077
It was worse on 10 hence downgraded to pie again! Very buggy. Hence waiting for the solution!
victor010
Zen Master III
Please follow below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
You may also recalibrate battery
To recalibrate battery, charge your phone to 100% without interruption.
then discharge it normally till 0%(phone gets switched off).
charge it to 100% in switched off condition and keep it in that state for a little more time.
now switch on your phone in charged condition and unplug when ASUS logo appears.
keep the phone unused for 5 mins.
you will get far better battery life as the battery stats.bin file will be updated.
