Not able update from QKQ1.WW_Phone-17.2017.2004.424-20200414. To. Version JP-16.2017.2007.084
gowdaks1994
Not able update from QKQ1.WW_Phone-17.2017.2004.424-20200414  To the latest Version JP-16.2017.2007.084
File is not recognising when I pasted it on root folder.
4 REPLIES 4
artyom_batinkin
gowdaks1994
JP-16.2017.2007.084 is update for Android 9 build. WW_Phone-17.2017.2004.424-20200414 is Android 10. So you was not able to install this image.
gowdaks1994
Then should I have to wait for stable release ???
Debasish_Sahoo
Zen Master I
gowdaks1994
Yes because beta may contain some bugs so wait for the stable release
Y_ASUS
Zen Master I
Hi gowdaks1994,
If you'd like to install WW-16.2017.2007.084, you'll have to downgrade to Android 9.
Please find "Version MaxProM1_downgrade_to_9" in the link below:
ZenFone Max Pro(M1)(ZB601KL) | ASUS Global
System downgrade will wipe all the personal data, please backup your important data before system downgrade.
Steps of Update:
1. Prepare a MicroSD card.
2. Check software version of your device**
3. Only apply to same SKU update, Example: WW->WW, CN->CN, TW->TW, ID->ID.
4. Software update cannot transfer the software SKU.
5. Wrong SKU may cause update failure, please update the same SKU version only.
6. How to manual update firmware please refer to
https://www.asus.com/support/FAQ/1042349
