Microphone not working during loudspeaker calls or video calls
varun275
Model Name: max pro m1
Firmware Version: 0.84
Rooted or not: no
Frequency of Occurrence:
With normal calls everything is working fine.
But when put calls on loudspeaker, person other side not able to hear anything.
This is same for video calls. Person other side is not able to hear anything .
I have done hard reset and factory reset both but problem still persist.
Any solution please help. ?
varun275
@Asus zenfone please help and fix it ASAP
victor010
Zen Master III
Hi, request you to enter into SMMI test to check if there is any issue with the hardware.
Go to Calculator=>type " .12345+= "
you will be entered to SMMI_TEST_V4.1.35
Select Receiver1_Test=>Press Start to check
If the problem persists, we suggest you to please visit the nearest ASUS service center for better assistance. Locate here : https://www.asus.com/in/support/Service-Center/India
