Mic is not working (only in calls)
Microphone not working just for the calls.
But it is working when i use the loudspeaker option/wired headset/Bluetooth headset in callsand when i use sound recorder/video recorder. Just not in a normal call.
When i go out i have to use a headset each time i get a call or have to speak in loudspeaker.
victor010
Zen Master III
Hi, kindly help us with the following information to find a solution to your query.
1.  Name of the Asus device you are using.
2.  Firmware version your device is on.
3. Request you check with another headset and check if the issue persists.
