Max pro m2 idle battery drain when fingerprint sensor is turned on.
Ambadi
Max pro m2 battery drain when fingerprint sensor is turned on(only when phone is in idle condition) . Changed software and sensor but of no use.
11 REPLIES 11
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also, kindly share with us the firmware version of the device.
Ambadi
There is no unsual battery drain when phone is in use. Also no problem with the SOT. Battery graph is not detecting ideal battery drain.
abhaykrishnan02
Zen Master I
Ambadi
will u please share screenshot of
running services and chached process from developer option
Ambadi
