Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-18-2020 11:27 PM
1 ACCEPTED SOLUTION
Accepted Solutions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2020 08:09 PM
Hi haribabu9533
Thank you for your asking. Kindly provide the information below so that we can better assist you.
1. Does the issue appear right after the system update?
2. Does the mic issue appear with Calling or any specific apps?
3. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
4. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
12 REPLIES 12
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2020 08:09 PM
Hi haribabu9533
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2020 10:13 PM
I'm trying these two methods but same problem again 1. Does the issue appear right after the system update? YES
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2020 11:02 PM
Hi haribabu
1. Does the mic issue appear with Calling or any specific apps?
2. Please check on SMMI test
Calculator> type ".12345+=">SMMI TEST>Single Test>BoardMic Test/BoardMic2 Test
If any of the SMMI tests fails, indicating high possibility of faulty hardware, kindly bring your device to the nearest ASUS repair center for device checking: https://www.asus.com/support/Service-Center-All-Countries/
If it is impossible to access the service center during Covid-19 period, please try Call us: https://www.asus.com/support/CallUs
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2020 07:23 PM
1. Does the mic issue appear with Calling or any specific apps? MIC APPEAR ONLY WITH NORMAL CALL
When call through whatsApp mic working, But only normal call mic not working properly.
Calculator> type ".12345+=">SMMI TEST>Single Test>BoardMic Test/BoardMic2 Test SURE
