[Max Pro M2] I got this fota update today! Should I update or not?? Are there any bugs??
chaudharyprakas
41 REPLIES 41
chouhan
Rising Star I
Guys be careful while updating FOTA, Lot of Asus Max Pro M2 devices crashed completely and not booting up at all after 073 FOTA rolled out by Asus which was having a glitch. We are struggling now but company is not taking any responsibility they are straightaway asking to replace complete motherboard for which they are charging 9 to 10 k.
If you wish to check please search "Asus Zenfone Max Pro M2 stuck on asus logo" in zentalk you can see huge number of people facing such issue their devices including mine is unusable from last 2 months.
chouhan
Rising Star I
saurabhbhola80
veeharish2005
https://zentalk.asus.com/en/discussion/comment/85660#Comment_85660
This update is rolling out batch by batch
So you will get the update in coming days
Yes today I received in m1
I have updated.....
To get restart phone then check for update I think you will get update I have also done this today
To restart press and hold power button then restart....
saurabhbhola80
chaudharyprakash404
https://zentalk.asus.com/en/discussion/comment/86008#Comment_86008
I am also facing the same problem bro!! It's taking 4 hours to full charge. Even I use earphone, sound is coming from main speaker sometime!!
Same problem in my phone also in m1
tatarajatps
Tech_Talk
https://zentalk.asus.com/en/discussion/29502/i-got-this-fota-update-today-should-i-update-or-not-are...
There are no bugs till now. Its just the May security patch which was pushed few days ago. You should update to it using the FOTA and since its a stable update in Pie, you have to have it on your phone so that if the next update would be the Stable Android 10 (just saying for example, there's no confirmation) then the system won't recognise the Stable Android 10 FOTA because of your device Firmware as an older one (.075). What I meant to say, to receive the next FOTA, you have to be on the latest firmware version only. Otherwise at that moment, you would be required to update to that last version manually, only after that you will be able to install the latest one.
Chrome update released recently can we install this now? Because earlier update of chrome stopped all apps not working. Can we update this chrome now? please suggest.
