05-28-2020 02:47 AM
05-28-2020 03:50 AM
05-28-2020 05:31 AM
gbunHi team,
I updated to max pro m2 with latest .424 build of android 10 beta and i see the bugs please asus fix this bugs and give the next ota fast. Bugs in max pro m2 I,m facing which is given below
- slow charging:- when i plug the phone with original charger of asus then after 5 min it showing rapid charging after half an hour after that it showing charging which charge the phone with normal speed after 5 to 10 minutes its showing slowly charging and it takes more time to charge generally it occurs (slowly charging) after 40 percent of charging. This is the serious issue I'll facing.
- round corner is missing in the bottom edges
- ringing and notification sound is low
- in speaker there is no bass and sound is also very low and in pie build it is ok
- and the suggestion from setting is not removing
- notification light blinks sometimes green sometimes yellowish white
max pro m2 beta 2 bugs
05-28-2020 07:30 AM
gbunYes @gbun I am also facing that issue.https://zentalk.asus.com/en/discussion/29212/max-pro-m2-beta-2-bugs
after factory reset bass is also gone in earphones audio and google news feed become blank
05-28-2020 07:52 AM
aadityagujjar3i am thinking to downgrade to pie no doubt 10 is amazing but it takes lot of time to charge in 10 and sound is also bass lesshttps://zentalk.asus.com/en/discussion/comment/84067#Comment_84067
Google feed is blank after updating.
