max pro m2 beta 2 bugs
gbun
Hi team,
I updated to max pro m2 with latest .424 build of android 10 beta and i see the bugs please asus fix this bugs and give the next ota fast. Bugs in max pro m2 I,m facing which is given below
slow charging:- when i plug the phone with original charger of asus then after 5 min it showing rapid charging after half an hour after that it showing charging which charge the phone with normal speed after 5 to 10 minutes its showing slowly charging and it takes more time to charge generally it occurs (slowly charging) after 40 percent of charging. This is the serious issue I'll facing.
round corner is missing in the bottom edges
ringing and notification sound is low
in speaker there is no bass and sound is also very low and in pie build it is ok
and the suggestion from setting is not removing
notification light blinks sometimes green sometimes yellowish white
17 REPLIES 17
Raze
is there a new update for beta 2???
Y_ASUS
Zen Master I
Hi Raze,
Thanks for your inquiry.
Please stay tuned with us on our support site for the latest news: 🙂
https://www.asus.com/in/Phone/Zenfone-Max-Pro-M2-ZB630KL/HelpDesk_BIOS/
Release Notes (EN) — ZenTalk
Huda
It has been more than 75 days and still no update for beta 2 user's. It's so irritating man. We are the worst sufferer but you don't care about us.
