max pro m1 beta 4 432 update>No network strength icon
Ghostrish26
【Version】
17.2018.2008.432
【Model Name】
ZenFone Max Pro (M1) ZB602KL
New bug added after 432 update.
1. No network strength is showing on notification panel only showing volte logo.
23 REPLIES 23
Sound quality is not good as pie.& Also noticed that the network strength bar icon is not shown in the notification panel.Only shows 4G after connecting Data connection.Otherwise it's empty.
Christine_ASUS
Community Legend II
Hi dibyajyotimukherjee0
Thank you for your asking.
The network strength bar icon >
Because my device does not have the same situation. Please try the troubleshooting tips I mentioned above. If the situation remains the same, please provide me your model and the firmware version.
Sound >
To avoid overlapping threads, kindly refer to the links below
MPM1
https://zentalk.asus.com/en/discussion/36394/
MPM2
https://zentalk.asus.com/en/discussion/36306/
kolonja
I am new in this forum, and I have the following problem, the VoLte icon stays on the bar regardless of switching OFF the WiFi calling, is there a way to get rid of the icon. It appeared after the last update, and callers are complaining that they cannot hear me.
Please help.
ASUS_Bot
Rising Star II
