07-07-2020 04:33 AM
08-17-2020 11:03 PM
zamakiyakishanHi zamakiyakishan,https://zentalk.asus.com/en/discussion/comment/103361#Comment_103361
I already sent this device but I not got any solution till now I already send RMA number in previous chat see that.
08-17-2020 11:14 PM
08-18-2020 08:55 AM
Y_ASUSIm using original charger and original cable my build number is 429 android 10 beta3https://zentalk.asus.com/en/discussion/comment/103884#Comment_103884
Hi muthum570,
Are you using the original charger? Please try with new cables as well.
Please let us know your model and firmware version.
08-18-2020 09:15 PM
zamakiyakishan15. This feature is not in A10 Beta 3Model : Asus Zenfone Max Pro M1
: ZB601KL
Build Number-
(QKQ1.WW_Phone-17.2017.2006.429-20200614)
1) Sound quality through earphones is still weird. (No bass effect)
2) Setting suggestion is not removable. {E.g-Turn On You Data }
3) Huge gap in navigation button while using android 10 special gesture navigation
4) Google search widget is not removable.
5) Charging vibration is too loud.
6) No option to desable vibration when unlock with fingerprint.(when fingerprint rejected its vibration is GOOD and Natural but when fingerprint accepts its vibrate like android 9 charge connect vibration and no option to desable it)
7) Discharge in idle mode.
😎 Something app menu blank
9) In dark mode ,white background in Setting search
10) When call from another phone, its showing call notification after 4 seconds,and then asus rings for only 2 second.(during total 6 second of ringing)
11) Some Time Device Heat Issue
12) Front Camera To Much Poor Results
*battery*
When Charging
15%-40% =200mA-400mA
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
90%-95% =400mA(showing Rapidly charging)
95%-100% =300mA-400mA (Not rapidly, Normal charging)
13. Heating Issue while Charging (From Original Charger)
14. At time of incoming calls sound quality is poor and no notification sound on time of notification only they vibrate
15. Missing feature of screen colour in display settings.
16. Navigation Buttons stop responding some time.
17. These issues is in stable also screen stop responding many time. Touch response not work properly.
18. Manly please add WiFi calling feature.
19. Camera quality of front is too much poor than older version of camera app.
List Of Bugs In Asus Zenfone Max Pro M1 | .429 Beta 3 Update
