Installing Stock ROM Not Working?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-17-2020 07:43 AM
Model Name: Zenfone Max Pro M2 ASUS_X01BDA (ZB631KL-4D103TW)
Firmware Version: OPM1.WW_Phone-15.2016.1902.192-20190226
Rooted or not: not rooted, bootloader unlocked - yes
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): Can't re-install stock ROM
A. I tried installing LineageOS tonight: booted into TWRP recovery, wiped everything, tried to sideload LineageOS but said my firmware was too old (Said I needed at least 16.2017.1905.065)
B. Now I'm trying to go back to stock android ROM, so I can update the firmware.
C. Downloaded the file UL-ASUS_X01BD-WW-16.2017.2005.092-user.zip from ASUS website.
D. Booted into TWRP, tried to use 'adb sideload UL-ASUS_X01BD-WW-16.2017.2005.092-user.zip' to load stock ROM but I get the error:
"E3004: This package is for "ASUS_X01BD" devices: this is a "X01BD".
I also tried puting the zip file into / directory, and rebooting. That didn't work.
So now I have a phone with no operating system, stuck in fastboot/TWRP.
Any suggestions how to get stock ROM back on the Zenphone? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-18-2020 06:57 AM
elias888As per XDA developer guide , When you flash stock ROM zip file directly from ASUS site , TWRP or any recovery will get replaced with stock one. In XDA developer fourm there are custom Recovery flashable zip available for 72 73 and 75 versions. Even there are steps provided for installation of firmware from ASUS official zip file with out loosing custom recovery.Update!
- I got into TWRP fastboot, tried to adb sideload Lineage right away but still said I didn't have the right firmware. In Asus recovery it said I had PKQ1.16.2017.1910_071-20190920
- So I sideloaded a stock ROM and it worked!
- Looking in Settings - System - About Phone and it says i have build number: PKQ1.WW_Phone-16.2017.2005.092-20200518. It seems I should be good to install Lineage OS now. I just have to work up the courage to try again 😄
I am using Havoc Os with 424 latest beta firmware. It's working smoothly.
My another suggestion.
At present Android 10 based lineage OS is not available officially. But unofficial ROM is there in XDA fourm. Meanwhile you can use Android 9 official version
If you need offical 10 based ROM then you can try Pixel experience for pure UI Havoc OS for high customisation , Stock mod for UI near to stock rom with better performance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-18-2020 07:28 AM
I went back to install LineageOS 16.0 and it worked! Success!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-19-2020 06:05 AM
vckanandvppTry Paranoid android rom u will definitely love it if u don't want any customisationhttps://zentalk.asus.com/en/discussion/comment/90225#Comment_90225
Unofficial lineage 17.1 by rk also too good
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-19-2020 08:16 AM
kprsntCan you give a good link for anyone starting to shift to custom rom from stock rom who hasn't used any tool before?https://zentalk.asus.com/en/discussion/comment/90237#Comment_90237
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-21-2020 01:08 AM
AnanduXDA developer fourm is the best platform to learn about how to use custom ROMhttps://zentalk.asus.com/en/discussion/comment/90527#Comment_90527
Unlocking bootloader , installing recovery , installing new rom , custom Google apps , Rooting( If needed) etc you can get any information from there
