06-17-2020 07:43 AM
06-18-2020 06:57 AM
elias888As per XDA developer guide , When you flash stock ROM zip file directly from ASUS site , TWRP or any recovery will get replaced with stock one. In XDA developer fourm there are custom Recovery flashable zip available for 72 73 and 75 versions. Even there are steps provided for installation of firmware from ASUS official zip file with out loosing custom recovery.Update!
- I got into TWRP fastboot, tried to adb sideload Lineage right away but still said I didn't have the right firmware. In Asus recovery it said I had PKQ1.16.2017.1910_071-20190920
- So I sideloaded a stock ROM and it worked!
- Looking in Settings - System - About Phone and it says i have build number: PKQ1.WW_Phone-16.2017.2005.092-20200518. It seems I should be good to install Lineage OS now. I just have to work up the courage to try again 😄
06-18-2020 07:28 AM
06-19-2020 06:05 AM
vckanandvppTry Paranoid android rom u will definitely love it if u don't want any customisationhttps://zentalk.asus.com/en/discussion/comment/90225#Comment_90225
I am using Havoc Os with 424 latest beta firmware. It's working smoothly.
My another suggestion.
At present Android 10 based lineage OS is not available officially. But unofficial ROM is there in XDA fourm. Meanwhile you can use Android 9 official version
If you need offical 10 based ROM then you can try Pixel experience for pure UI Havoc OS for high customisation , Stock mod for UI near to stock rom with better performance.
06-19-2020 08:16 AM
kprsntCan you give a good link for anyone starting to shift to custom rom from stock rom who hasn't used any tool before?https://zentalk.asus.com/en/discussion/comment/90237#Comment_90237
Unofficial lineage 17.1 by rk also too good
06-21-2020 01:08 AM
AnanduXDA developer fourm is the best platform to learn about how to use custom ROMhttps://zentalk.asus.com/en/discussion/comment/90527#Comment_90527
