IDLE BATTERY DRAINING ISSUE IN ASUS ZEFONE MAX PRO M1
psaravanankarur
Model Name:max pro m1
Firmware Version:0.87
Rooted or not:not
Frequency of Occurrence:
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
