Idle battery drainage
worpt
Frequency of Occurrence: daily
Firmware/APP Version: WW_Phone-16.2017.1910.059-20190920
RAM: 6G
ZF Model: ZB601KL
APP Name:
Rooted: No
Last edited by worpt on 2019/12/20 07:09 Hey, the issue is that battery of my phone drains very fast even when I don't use it. Sometimes in the morning I found it switched off. This is happening since these new updates came.
16 REPLIES 16
ZT-6b3b372f
Do recalibration battery proses
ZT-6b3b372f
Just do recalibration battery process
ZT-6b3b372f
worpt
Last edited by worpt on 2019/12/25 09:48 Tested again on .60 firmware disabling fingerprint and Digital wellbeing — battery dropped from 75% to 72% in 8 hours. (Fingerprint and Digital wellbeing were disabled).
suryacoool07
Hi there, we'd request you to follow the below steps may improve battery backup: 1. Enable “Power saver” (Settings >Power management) 2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.) 3. Adjust sleep time and brightness (Settings > Display) 4. Boost memory when you see memory consumes is high with no app running, 5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
