Heating issue and battery drain
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-18-2019
03:49 AM
- last edited on
01-16-2024
01:03 AM
by
ZenBot
After having feb update im lossing so much battery power and its heating when its charging.Its also heating when im playing pubg.😒
23 REPLIES 23
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-21-2020 10:42 PM
I am experiencing a battery drain and extreme heat on my Zenfone Max Pro M1.The battery drained from 25% to empty in just under 20 minutes.I checked on the app Ampere and the usage is around 1700mA which normally it is around 300mA while in standby.The phone also keeps heating up even after i turned it off.When i plugged the charger in,it wont charge but instead it just heat up crazily.Im using the latest software which is WW-16.2017.2002.061.What is causing this problem?Is it the component other than the battery or the battery itself?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-01-2020 08:18 PM
Same here overheating in the latest update.. in max pro m2. This update security level is april 2020. My max pro m2 is overheating. Please repair mobile bugs and new update send for max pro m2 mobile
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-07-2020 09:11 PM
Yes I've also started experiencing this issue. My mobile battery just won't charge up. I had to power it off and then it got charged up that to at very low speed. And when i left it as it is in the night, i touched it and it was touching 39 degress according to cpu Z. My software is latest and upto date.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-07-2020 10:11 PM
I have also same problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-08-2020 11:39 AM
