First impression of MP M2 update WW-17.2018.2004.424
Riju9547
Rising Star II
Model Name:ZB630KL/ZB631KL
Firmware Version:WW-17.2018.2004.424
Rooted or not:NO
Frequency of Occurrence: CONSTANT
APP Name & APP Version (If your issue relates to the app):NONE
The bugs i found in last 12 hours.
The sound from the phone speaker is very bad. It decreased a lot. I cant hear my ringtone in the incoming call. and while watching YouTube i have to keep my volume at 100% to listen properly. And if I keep the volume at 70 or 60 % I cant hear anything properly the volume is too low. But the clarity increased. And the sound via headphone (wired/wireless) seems of for me and I personally think it was better than the previous beta update (409). The sound via earpiece is also OK(will prefer a little bit louder)
The Rounded corner in the bottom of the screen are gone.
There is a popup message in the Settings which says to customize your ZB630KL. Which you cannot remove.
Bugs got fixed
The UI is buttery smooth
The is no App crash issue
Battery backup is amazing
Gcam works perfectly( Version 7.0.009). The same version used to have saving and crash issue.
Low volume voice recording in whats app and in Discord call got fixed
24 REPLIES 24
Ikki
Riju9547
https://zentalk.asus.com/en/discussion/comment/83446#Comment_83446
From which version you upgraded to android 10. and what method you used?
I upgraded from android 9 (I'm sorry can't remember the specific version). I manually updated from Asus.com.
Riju9547
Rising Star II
Ikki
https://zentalk.asus.com/en/discussion/comment/83453#Comment_83453
for android 9 user this version is specific for WW-16.2017.1910.071 & WW-16.2017.1912.072 . Try to factory reset maybe it can fix some of the problem your are having
Ikki
Riju9547
https://zentalk.asus.com/en/discussion/comment/83456#Comment_83456
As much as possible I'm trying to avoid doing factory reset. Is there no other way??:(
Riju9547
Rising Star II
Ikki
https://zentalk.asus.com/en/discussion/comment/83458#Comment_83458
I can only suggest some tips related to the charging issue. I used to have the charging problem in A9 but after I changed my USB cable it got fixed then again after few months I had the same problem then I cleaned the dust in the port and the problem was fixed. now in A10 beta 2 i don't have the problem . when you plug in the USB its shows 'charging slowing' then after few mins it show 'charging' then after few minutes it shows 'charging rapidly'. and if you try to charge your phone above 75% then it will only show 'charging' only. So try to change the cable if that does't work then take a screenshot of the lock screen with the estimated charging time and make a forum so that developer can see your post
Ikki
Riju9547
https://zentalk.asus.com/en/discussion/comment/83463#Comment_83463
Okay thankyou! I just noticed right now the charging issue is improving. But how about in the earphones issue.. what can you suggest about it?
