First impression of MP M2 update WW-17.2018.2004.424
Riju9547
Rising Star II
Model Name:ZB630KL/ZB631KL
Firmware Version:WW-17.2018.2004.424
Rooted or not:NO
Frequency of Occurrence: CONSTANT
APP Name & APP Version (If your issue relates to the app):NONE
The bugs i found in last 12 hours.
The sound from the phone speaker is very bad. It decreased a lot. I cant hear my ringtone in the incoming call. and while watching YouTube i have to keep my volume at 100% to listen properly. And if I keep the volume at 70 or 60 % I cant hear anything properly the volume is too low. But the clarity increased. And the sound via headphone (wired/wireless) seems of for me and I personally think it was better than the previous beta update (409). The sound via earpiece is also OK(will prefer a little bit louder)
The Rounded corner in the bottom of the screen are gone.
There is a popup message in the Settings which says to customize your ZB630KL. Which you cannot remove.
Bugs got fixed
The UI is buttery smooth
The is no App crash issue
Battery backup is amazing
Gcam works perfectly( Version 7.0.009). The same version used to have saving and crash issue.
Low volume voice recording in whats app and in Discord call got fixed
24 REPLIES 24
Riju9547
Rising Star II
gbun
Riju9547
https://zentalk.asus.com/en/discussion/comment/83506#Comment_83506
Yes
how much time it take to charge
is eis is working on your device
Bryz
The action mode and nigth mode on the front camera not working
Riju9547
Rising Star II
Bryz
Use GCAM for better photography... Disable the stock cam. There is not reason to use stock camera
karsanapalliman
Rising Star I
Stable update not received my please fota only upgrade in my phone some bugs are not improve them so fota update improvement in them battery life will more in them change ing very so then
