First impression of MP M2 update WW-17.2018.2004.424
Riju9547
Rising Star II
Model Name:ZB630KL/ZB631KL
Firmware Version:WW-17.2018.2004.424
Rooted or not:NO
Frequency of Occurrence: CONSTANT
APP Name & APP Version (If your issue relates to the app):NONE
The bugs i found in last 12 hours.
The sound from the phone speaker is very bad. It decreased a lot. I cant hear my ringtone in the incoming call. and while watching YouTube i have to keep my volume at 100% to listen properly. And if I keep the volume at 70 or 60 % I cant hear anything properly the volume is too low. But the clarity increased. And the sound via headphone (wired/wireless) seems of for me and I personally think it was better than the previous beta update (409). The sound via earpiece is also OK(will prefer a little bit louder)
The Rounded corner in the bottom of the screen are gone.
There is a popup message in the Settings which says to customize your ZB630KL. Which you cannot remove.
Bugs got fixed
The UI is buttery smooth
The is no App crash issue
Battery backup is amazing
Gcam works perfectly( Version 7.0.009). The same version used to have saving and crash issue.
Low volume voice recording in whats app and in Discord call got fixed
24 REPLIES 24
Riju9547
Rising Star II
I attached the screenshots here
Ikki
My phone charges slowly is it really like that? And when I use my earphones the audio quality is poor. It's like the bass is missing. Please help.
Ikki
And one more thing, everytime I restart my phone some settings in the developer options automatically turn on.
Riju9547
Rising Star II
Ikki
From which version you upgraded to android 10. and what method you used?
