First impression of MP M2 update WW-17.2018.2004.424
Riju9547
Rising Star II
Model Name:ZB630KL/ZB631KL
Firmware Version:WW-17.2018.2004.424
Rooted or not:NO
Frequency of Occurrence: CONSTANT
APP Name & APP Version (If your issue relates to the app):NONE
The bugs i found in last 12 hours.
The sound from the phone speaker is very bad. It decreased a lot. I cant hear my ringtone in the incoming call. and while watching YouTube i have to keep my volume at 100% to listen properly. And if I keep the volume at 70 or 60 % I cant hear anything properly the volume is too low. But the clarity increased. And the sound via headphone (wired/wireless) seems of for me and I personally think it was better than the previous beta update (409). The sound via earpiece is also OK(will prefer a little bit louder)
The Rounded corner in the bottom of the screen are gone.
There is a popup message in the Settings which says to customize your ZB630KL. Which you cannot remove.
Bugs got fixed
The UI is buttery smooth
The is no App crash issue
Battery backup is amazing
Gcam works perfectly( Version 7.0.009). The same version used to have saving and crash issue.
Low volume voice recording in whats app and in Discord call got fixed
24 REPLIES 24
Riju9547
Rising Star II
Ikki
https://zentalk.asus.com/en/discussion/comment/83479#Comment_83479
Okay thankyou! I just noticed right now the charging issue is improving. But how about in the earphones issue.. what can you suggest about it?
sorry I don't know any way to improve that. but for max pro M1 user there is a way to flash a NXP zip file with TWRP recovery mode but that's not a official way and there is no guarantee that it will be safe and you cannot uninstall that file. so I am not suggesting the method. wait for the next update
vamsi
How is the NAV bar issue, is it still big and black?
Ikki
Riju9547
https://zentalk.asus.com/en/discussion/comment/83485#Comment_83485
Okay, thankyou! 😄
Riju9547
Rising Star II
vamsi
no its normal as it should be
gbun
Riju9547
https://zentalk.asus.com/en/discussion/comment/83487#Comment_83487
is your device is certified
