Hi
gomes.tisystemThank you for your reply.
1. Which earphones brand and model are you using? Can other bluetooth earphones model work with your device?
2. Can your earphones work with other phone in Android 10?
If the situation remains after performing the Factory Reset, you may follow the steps below as 10 to 9 downgrade steps to use your current earphones' model.
1. Download "MaxProM2_downgrade_to_9" and then put the image file into the root directory of the MicroSD card.
https://www.asus.com/br/Phone/ZenFone-Max-Pro-M2/HelpDesk_BIOS/2. Insert MicroSD card into phone and then power off the device.
3. Long press with "Power" key and "Volume Down" key together and stop after feel the vibration to enter Recovery Mode
4. Use "Volume Down/Up" key and press "Power" key to choose "Apply update from external storage"
5. Select the downgrade file
6. When the updating process is done, Choose "Wipe data/factory reset" and tap"Yes" to perform the master clear.
7. "Wipe cache partition" > "Yes"
8. "Reboot system now"
#Android 10 to Android 9 Guide
https://www.asus.com/support/FAQ/1042349
