Dual band WiFi (5.8 ghz) is not supported in Max Pro M2
indyj7717
Dual band WiFi (5.8 ghz) is not supported in Max Pro M2. Is there anyway that can be fixed?
7 REPLIES 7
indyj7717
Christine_ASUS
Hi indyj7717
Thank you for your asking. Which country do you locate? I will check the device spec for you.
India. I've checked it only supports 2.4 ghz. I'm just asking if it can be fixed if Asus provides an update.
Christine_ASUS
Community Legend II
Hi indyj7717
Thank you for your asking. "Spec" is a hardware thing, which can not be improved by software update.
indyj7717
Christine_ASUS
Hi indyj7717
Okay thanks. I suspected that.
