Draining battery issue of Zenfone Max Pro (version firmware .087)
Model Name: Zenfone Max Pro (M1) [ZB602KL]
Firmware Version: WW-16.2017.2009.087
Rooted or not: No
Frequency of Occurrence: Since last firmware updates first week of September 2020
I've done some research and read few same problems regarding this phone and last firmware updates (.087).
I'm experiencing the same problem related to draining battery overnight in idle state. I strongly think it's not about the battery itself having the problem but it's more about the bugs coming with the last firmware updates. Many people experiencing batteray drain issue with the same firmware updates.
And all your team suggesting just either charging our phone in safe mode or just throw "reset your phone" card useless solution to our faces. I find it useless because people still getting the exact problem so i think it's the bug coming with this firmware updates that causes the phone's battery draining fast when it's not used.
Hereby i attached my latest battery usage and it seems pretty abnormal. I have set my battery safer on, on purpose. And my SOT is just less than an hour with less than half hour only using two apps but the battery draining already down for almost 10% just less than an hour. I don't instal any apps since months ago and nothing changed with my phone and my daily usage is literally the same. I just feel the drained battery issue starts happening since last updates early of this month.
Please review your system updates and please fix this bug issue because my core decision i choose this phone because its huge battery capacity but i don't feel the exellence of its battery performance now.
6 REPLIES 6
AJ1
Rising Star II
febrianasariebut
  1. Model Name: Zenfone Max Pro (M1) [ZB602KL]
  2. Firmware Version: WW-16.2017.2009.087
  3. Rooted or not: No
  4. Frequency of Occurrence: Since last firmware updates first week of September 2020
Yes buddy that's true, even I'm facing same issues tried all ways nothing happened, & asus for many solutions tell only to reset the device or else visit to SC which is not good. Company has dissatisfied many users but still not accepting that firmware updates that are rolled out have bugs in it
AJ1
Rising Star II
vishnusdz013
Can you please try turning off the fingerprint sensor and now check whether there is battery draining overnight or not. I had the same issue but after this battery was doing ok.
And if that's the case for every user then asus has to rectify this problem in the next update ✌️
Don't think on it also
