Device not certified
rahulraman066
Model name Asus zenfone max pro m1
Firmware Version: 438
Rooted or not:. Not
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app): device not certified
My device is not certified in the Google Play Store. My firmware version is 438 Android 10. Please provide a solution.
Not applicable
rahulraman066
  1. Model name Asus zenfone max pro m1
  2. Firmware Version: 438
  3. Rooted or not:. Not
  4. Frequency of Occurrence:
  5. APP Name & APP Version (If your issue relates to the app): device not certified
This problem is also with my device
umashankarsatna
PROBABLY THIS PROBLEM IS DUE TO DEVELOPER OPTION ON WHILE UPDATING TO THE FIRMWARE....AND IF GCAM NOT WORKING FINE THAN JUST SIMPLY TURN OFF SDEVELOPER OPTION AND IT WILL WORK.
victor010
Zen Master III
Hi, kindly follow the below steps:
Clear system cache.
Clear google updates, app cache and app storage.
If still you face the issue factory reset your phone after taking a full backup: https://www.asus.com/support/FAQ/1006346/
