Device Is Corrupt And Can Not BE Trusted
anmoluppal01
ZF Model: ZB601KL
RAM: 4G
Firmware/APP Version: .053
Frequency of Occurrence: Very high
Rooted: No
APP Name:
My device is showing your device is corrupt and cannot be trusted Error while booting Up. I tried Resetting My device, wiped cache partition and now when I am trying to flash Stock ROM based on Oreo My Device Is not being detected by adb. Is there A solution.?
47 REPLIES 47
anmoluppal01
Kunnu posted on 2019/5/29 19:03 No offence but it seems you are doing something wrong !!!! Try different fastboot rom and are u fl ...
None Taken..I've downloaded two fastboot oreo roms. Not Able to flash either of them. And yup I am flashing in fastboot
ZT-7281f0b7
anmoluppal01 posted on 2019/5/29 19:19 None Taken..I've downloaded two fastboot oreo roms. Not Able to flash either of them. And yup I am ...
Download the files.... windows driver zip file and replace .zip from adb setup add .exe
anmoluppal01
Kunnu posted on 2019/5/29 19:35 Download the files.... windows driver zip file
UPDATE: I flashed Oreo Rom. Worked Fine With No Errors. Updated To PIe .53 The Issue Came Up Again. Back to Square One 😞 Plus The Service Center Is Far and cannot be reached.. Please HELP
ZT-7281f0b7
anmoluppal01 posted on 2019/5/29 21:25 UPDATE: I flashed Oreo Rom. Worked Fine With No Errors. Updated To PIe .53 The Issue Came Up Again ...
For real !!!! 😮 Why in hell u again update to 053 when u flashed the oreo man.... :curse:
anmoluppal01
Kunnu posted on 2019/5/29 21:30 For real !!!! Why in hell u again update to 053 when u flashed the oreo man....
I just flashed it because i thought After Updating again it'll solve my problem. And I flashed Oreo Just because I thought Updating from Oreo to Pie Again Will Solve My Problem.. I am Fed Up with this device. This Update was good but just one issue...
