Device Is Corrupt And Can Not BE Trusted
anmoluppal01
ZF Model: ZB601KL
RAM: 4G
Firmware/APP Version: .053
Frequency of Occurrence: Very high
Rooted: No
APP Name:
My device is showing your device is corrupt and cannot be trusted Error while booting Up. I tried Resetting My device, wiped cache partition and now when I am trying to flash Stock ROM based on Oreo My Device Is not being detected by adb. Is there A solution.?
47 REPLIES 47
ZT-7281f0b7
is your device turning up ??? coz after reset u again have to enable usb debug.......then adb will be detect your device !!!!!
anmoluppal01
Kunnu posted on 2019/5/29 15:00 is your device turning up ??? coz after reset u again have to enable usb debug.......then adb will b ...
It Is Booting up. I've enabled USB Debug Gave All the permissions Set Default connection to MTP Updated all the drivers. Still Not Getting Detected
ZT-7281f0b7
anmoluppal01 posted on 2019/5/29 15:34 It Is Booting up. I've enabled USB Debug Gave All the permissions Set Default connection to MTP Up ...
Does "TRUST" popup appeared on ur device when connect to pc ( when "adb devices" command typd in cmd ) ???
anmoluppal01
Kunnu posted on 2019/5/29 15:40 Does "TRUST" popup appeared on ur device when connect to pc ( when "adb devices" command typd in cm ...
yes it did. i checked the tick box
