Device Is Corrupt And Can Not BE Trusted
anmoluppal01
ZF Model: ZB601KL
RAM: 4G
Firmware/APP Version: .053
Frequency of Occurrence: Very high
Rooted: No
APP Name:
My device is showing your device is corrupt and cannot be trusted Error while booting Up. I tried Resetting My device, wiped cache partition and now when I am trying to flash Stock ROM based on Oreo My Device Is not being detected by adb. Is there A solution.?
47 REPLIES 47
ZT-7281f0b7
anmoluppal01 posted on 2019/5/29 22:12 I just flashed it because i thought After Updating again it'll solve my problem. And I flashed Ore ...
C'mon bro....!!!! Now again enable usb debug and plug into pc and authenticate with adb device command.... then in fastboot flash the oreo :L
anmoluppal01
Kunnu posted on 2019/5/29 22:24 C'mon bro....!!!! Now again enable usb debug and plug into pc and authenticate with adb device com ...
Isn't there a better Solution for the error.?
ZT-7281f0b7
anmoluppal01 posted on 2019/5/30 06:44 Isn't there a better Solution for the error.?
No bro this is only the most easy and trusted way.......i downgraded today to 327 , didn't face any errors
anmoluppal01
Kunnu posted on 2019/5/30 10:48 No bro this is only the most easy and trusted way.......i downgraded today to 327 , didn't face an ...
Were You facing the same issue.?
ZT-7281f0b7
anmoluppal01 posted on 2019/5/30 12:04 Were You facing the same issue.?
Yep i did face the "waitng for device" error.... it was not detecting my device but after i reinstall all the required drivers and adb v1.3 , it was all good {:6_196:}
