06-22-2020
01:59 AM
- last edited on
01-16-2024
01:04 AM
by
ZenBot
06-22-2020 02:52 AM
veeharish2005Ya..i already did all of the above,is the problem persists with all the zenphone max pro series? Due to the update?https://zentalk.asus.com/en/discussion/comment/91147#Comment_91147
When there is a next update install It manually, do not update through fota
Or
Try to clear cache and data of those apps.
06-22-2020 03:19 AM
PrayushI don't think it is caused by the update .https://zentalk.asus.com/en/discussion/comment/91152#Comment_91152
06-23-2020 11:49 PM
06-24-2020 01:28 AM
victor2020ThanksHi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
veeharish2005Thankshttps://zentalk.asus.com/en/discussion/comment/91147#Comment_91147
Or
