Dark theme in Setting menu
AJ1
Rising Star II
Even if dark theme is applied from settings menu why then settings menu theme is not changing to dark theme? Is it by default or bug which is stopping to change settings menu theme to dark theme? Any idea how we can change settings menu theme to dark in max pro M1.?
9 REPLIES 9
AJ1
Rising Star II
Victor01_ASUS
Hi there, let us know the firmware version of the device and try restarting the device.
You may also, Clear system cache.
Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
OS version is A9
Firmware version is .087.
I have tried in safe mode as well as resetting the phone as well but still dark theme is not applied in settings menu.
AJ1
Rising Star II
veeharish2005
https://zentalk.asus.com/en/discussion/36418/dark-theme-in-setting-menu
Are you in android 9 or 10?
Android 9 with latest firmware update
AJ1
Rising Star II
veeharish2005
https://zentalk.asus.com/en/discussion/comment/118081#Comment_118081
That is how Google implemented dark theme in android 10
Is it by default for settings menu & that to photos / gallery apps also
veeharish2005
Zen Master I
AJ1
https://zentalk.asus.com/en/discussion/comment/118031#Comment_118031
OS version is A9
Google only implemented system wide dark mode in android 10. The dark mode in android 9 only makes the quick settings , apps drawer black.
AJ1
https://zentalk.asus.com/en/discussion/comment/118096#Comment_118096
Dark mode in every Google app will have a greyish black theme.
But dark mode only applies on settings app if your device have android 10. If your device has android 9 then you cannot change the theme of the settings app.
ansumanmaity100
veeharish2005
But Asus can change that ,giving us a pitch dark theme . That is what I am asking for
