Bugs In Asus ZM Pro M1 Android 10 Beta 3
sujanjsr0
Rising Star II
Bugs in Asus Zenfone Max Pro M1 Android 10 Beta 3
Build Number-
(QKQ1.WW_Phone-17.2017.2006.429-20200614)
Bugs Which was also present in Beta 1 & beta 2.and still not fixed in this new beta 3.
1) Sound quality through earphones is still weird. (No bass effect)
2) Setting suggestion is not removable. {E.g-Customize your ZB601KL suggestion in setting} (screenshot attached)
3) Huge gap in navigation button while using android 10 special gesture navigation. (Screenshot attached)
4) Google search widget is not removable.
5) Charging vibration is too loud.
6) no option to desable vibration when unlock with fingerprint.(when fingerprint rejected its vibration is GOOD and Natural but when fingerprint accepts its vibrate like android 9 charge connect vibration and no option to desable it)
7) discharge in idle mode.
😎 something app menu blank.(screenshot attached)
9)in dark mode ,white background in Setting search .(screenshot attached)
10)when i call myself from another phone, its showing call notification after 4 seconds,and then asus rings for only 2 second.(during total 6 second of ringing)
*battery*
When Charging
15%-40% =200mA-400mA
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
90%-95% =400mA(showing Rapidly charging )(screenshot attached)
95%-100% =300mA-400mA (Not rapidly, Normal charging)
Battery backup is good.
How to Fix sound problem temporary:
for sound problem though earphone - use poweramp app-set output Hi-Res Outout-select Sample rate 384kHz then restart your phone and quick play any song from poweramp through earphones.and turn the bass knob to full in Poweramp app equilizer. (Now you will have good sound quality only in poweramp app )
41 REPLIES 41
That means Charing of phone is not good and battery backup is also not good????
kirang1017
sujanjsr0
Build Number-
*battery*
When Charging
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
for sound problem though earphone - use poweramp app-set output Hi-Res Outout-select Sample rate 384kHz then restart your phone and quick play any song from poweramp through earphones. (Now you will have good sound quality only in poweramp app )
In Beta2 not able to install Netflix.. can anyone tell me in Beta3 can we install Netflix ???
dinildinesh07
Ok been using it for 2 days.
After a few restart I noticed that my phone got better.
1. Boot time now normal
2. Phone is now working constantly.
3. Battery works normally for me.
4. Sound quality is loud but low bass. But as I'm using musicolet MP3 player, I have already adjusted the sound for me ears so I don't have any issue. Only the default players are bad.
5.navigation buttons are still buggy sometimes.
6. Vibration still too high (can be good for some people but I just hate it)
6pslima2002
ankitsh0707
I'd tried last both beta, disgusting and both time I had to roll back to A9.
As I love music, I'm not going install A10 untill stable version arrive.
Thanks @sujanjsr0
There's a video on YouTube by some guy called 24by7everything who has the solution to HEADPHONE problem but not SPEAKER problem. (I'm on Beta 2, headphone sound is working fine)
If you only care about headphone sound quality, upgrade to Beta 2/3 and do that fix, bro
praveenrawat249
Itne mahine baad bhi ye beta update hi dere h . Pta nhi stable to kbi milega ya nahi
