07-03-2020 01:56 AM
Solved! Go to Solution.
07-03-2020 02:12 AM
dm.enterprises.mirza11Can you explain what is a turbocharger?Hi, I am using Asus zenfone Max Pro M2 model no. Asus_x01BDA, after updating 5 may security patch updat I am facing sound problem and some time turbocharger is gone and some it is appear. So, kindly solve my problem.
Why my phone's turbocharger has gone and how can I enable it again?
07-03-2020 02:12 AM
07-03-2020 05:33 AM
07-03-2020 05:47 AM
dm.enterprises.mirza11Explain with screen shotIf you have turbocharger software in your phone then, When you charge your phone (a tiny '+' symbol shows in battery) it charge less time or charge your phone quickly.
07-06-2020 12:16 AM
