Bugs In Asus ZM Pro M1 Android 10 Beta 3
sujanjsr0
Rising Star II
Bugs in Asus Zenfone Max Pro M1 Android 10 Beta 3
Build Number-
(QKQ1.WW_Phone-17.2017.2006.429-20200614)
Bugs Which was also present in Beta 1 & beta 2.and still not fixed in this new beta 3.
1) Sound quality through earphones is still weird. (No bass effect)
2) Setting suggestion is not removable. {E.g-Customize your ZB601KL suggestion in setting} (screenshot attached)
3) Huge gap in navigation button while using android 10 special gesture navigation. (Screenshot attached)
4) Google search widget is not removable.
5) Charging vibration is too loud.
6) no option to desable vibration when unlock with fingerprint.(when fingerprint rejected its vibration is GOOD and Natural but when fingerprint accepts its vibrate like android 9 charge connect vibration and no option to desable it)
7) discharge in idle mode.
😎 something app menu blank.(screenshot attached)
9)in dark mode ,white background in Setting search .(screenshot attached)
10)when i call myself from another phone, its showing call notification after 4 seconds,and then asus rings for only 2 second.(during total 6 second of ringing)
*battery*
When Charging
15%-40% =200mA-400mA
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
90%-95% =400mA(showing Rapidly charging )(screenshot attached)
95%-100% =300mA-400mA (Not rapidly, Normal charging)
Battery backup is good.
How to Fix sound problem temporary:
for sound problem though earphone - use poweramp app-set output Hi-Res Outout-select Sample rate 384kHz then restart your phone and quick play any song from poweramp through earphones.and turn the bass knob to full in Poweramp app equilizer. (Now you will have good sound quality only in poweramp app )
41 REPLIES 41
auw12345
Bug
Cannot play friendly multiplayer in pes 2020 after beta 3 update
Earlier i used to play by switching to lte and turning off enhanced 4g lte mode but after the beta3 update i cannot play anymore
Hello, I have updated to Beta version 3 recently.
I tried copying files from internal storage to sd card, but everytime I attempt it is switching off automatically interrupting the file transfer. Does anyone else faced this issue? Is there any solution to solve this bug locally ?
i can't change my notification tone in app whatsapp,maybe this one of the bug
veeharish2005
Zen Master I
rizkiansyahdimas
I don't have this bug In my device
mssivasangaran
Sometimes I am turn on the hotspot to connect with WiFi in my laptop but the data is not passing
