Battery draining overnight issue
vishnusdz013
Model Name: Max pro M1
Firmware Version: Android 8.1.0, Feb 2019 security patch
Rooted or not: No
Frequency of Occurrence:
I just brought a new zenfone max pro m1. For a week battery was going fine. But today it had drained 10 percent overnight while the phone was idle. I did not installed any apps recently. The device is running android 8.1.0 feb 2019 security patch that came preinstalled. I haven't updated it yet. Please help me. And which firmware till now is the most stable one without any bugs & battery draining. Please reply 🙏
41 REPLIES 41
Anandu
https://zentalk.asus.com/en/discussion/comment/99830#Comment_99830
Yes.
Switch off.
Hold power and vol down button till you see a menu on black background.
1. Select wipe data and ok
2. Select wipe cache and ok.
3. Select reboot.
Even after factory reset facing overnight battery drain same issue 😴
Attached screenshot for reference.
Also Battery SMMI test also shows battery ok as per screenshot.
Please help me out..
RadeonPS
Rising Star II
yaminimahajan21
https://zentalk.asus.com/en/discussion/comment/100072#Comment_100072
Service Center can be more helpful and do tell all the steps you took. Seems like a hardware issue.
