battery drain in max pro m2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-23-2020 04:23 AM
Model Name:max pro m2
Firmware Version:build 92 ( android 9)
Rooted or not: not
Frequency of Occurrence: regularly
battery drains fast....in full charging it takes 4 - 5 hrs to become 0% in normal use....battery drains even during sleep mode...I tried battery calibration but it didn't work...everyone saying it to be a software issue...
solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2020 04:27 AM
MunimWhen did you bought the phone.Please tell us some basic information before asking for help:
- Model Name:max pro m2
- Firmware Version:build 92 ( android 9)
- Rooted or not: not
- Frequency of Occurrence: regularly
- APP Name & APP Version (If your issue relates to the app):
solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2020 05:43 AM
it's not about battery health...
when i was in android 10 beta it was perfect...
but beta 2 had some serious audio issue so I switched back to android 9....
& boom....battery backup got down to 4 hr from full 8 hr+ in just 5 hr difference....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-29-2020 10:44 PM
Thank you for your asking. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
[Phone/Pad] How to Enter and Exit Safe Mode? | Official Support | ASUS GlobalAlso, you could try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If the issue remain the same, please enter Safe Mode and charge your device to 100%, put it in idle overnight and provide me the screenshot of
①Setting>Battery
②Setting>Battery>3 dots on the top"Show app usage"
Furthermore, is there any zone heating up while using/idling?
