06-21-2020 02:16 PM
06-22-2020 12:19 AM
06-22-2020 01:47 AM
naranahir36Still Lucyk man. I am facing the problem since February; and asus will tell to reset and clear cache safemode and the end. Every update will make it worse as now my phone switch off again and again. In settings i have screenshot of battery being 70% and the phone will shut in 10 min. (thats SD 665 AIE.) And yes it happens that my phones battery percentage keep changing and which makes my phone switch off many times.
YASAADo a battery calibration by doing the steps belowPlease tell us some basic information before asking for help:
- Model Name:ASUS ZENFONE MAX PRO M2
- Firmware Version:
- Rooted or not:NO
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
OK I AM GETTING THIS WIERD BUG WHERE THE PERCENTAGE OF BATTERY IS JUMPING FROM XYZ% TO 50%
I DON'T KNOW WHAT TO DO 😭 ITS REALLY ANNOYING
https://us.v-cdn.net/6031231/uploads/MV7HGBOBTJ5R/untitled-720p.mp4
SOMETIMES THE PERCENTAGE GETS STUCK ON XYZ%
E.G NOW ITS STUCK AT 99% AND SUDDENLY IT GOES TO 97% AND AGAIN GOES TO 99%
PLEASE SOMEONE HELP ME WITH THIS
I CAN'T GO TO SERVICE DUE TO LOCKDOWN
BATTERY BUG IN ZF MAX PRO M2
06-22-2020 01:49 AM
naranahir36Is your phone Asus zenfone max pro M2 then your phone does not have sd 665 .it has sd 660.Still Lucyk man. I am facing the problem since February; and asus will tell to reset and clear cache safemode and the end. Every update will make it worse as now my phone switch off again and again. In settings i have screenshot of battery being 70% and the phone will shut in 10 min. (thats SD 665 AIE.) And yes it happens that my phones battery percentage keep changing and which makes my phone switch off many times.
06-22-2020 03:30 AM
